Ha, we used to ride one of those towed behind a buggy in the dunes when we were kids. Lots of fun but sure would get hot, had to sit on an old blanket to keep from burning your assVW hood was the goto in the old days
Welcome to the site Bryan. Good to see you here. We will catch up soon enough at the SSSSI’ll definitely say, use whatever works! The sled is mainly used to get your ride to safety. The more weight that is applied on it the quicker it will wear out. The mayday board can cause sparks and with all of the recalls on all of the SXS’s. It’s definitely dangerous. Hard to say no to a lifetime warranty though. If any of you choose to buy one use code newcustomer10 at checkout.
It is designed to be a one time use.I bought a safe sled and loaned it to a guy in need. He said it was pretty tore up after they got out of the dunes and across a gravel parking lot. Depending on the distance and what you are dragging it across it may be a one time use.
Thanks man! I definitely don’t do this for the money as I make pennies on how much I spent to get this product up and running. I’m really hoping one day to improve the design to last longer and handle bigger vehicles within other terrains! I’m lucky to have a supportive wife that allows me to do this since I’m unable to work a normal job anymore.
Unfortunately, I’m not physically there, but I definitely donate a sled or two when needed for the charity of these events. I am hoping to make a trip out this Halloween for camp rzr. Been about seven years since I’ve been out to Glamis. He’ll definitely see me at sand show this year!Thank you Bryan. It helps to share all this as people want to know who's behind the products. We've met several times but since then, I have acquired this forum. I am glad you joined and hope you find this place a good one to discuss you products, your outreach, and your support for Glamis and the community. It's people like you who support the industry with innovations and drive that make Glamis and this forum a better place.
Bryan is at most events supporting clean ups, veterans, gatherings etc. Humble as the day is long and proud of his product.
My future plans are to find a more durable material that has the capability to be molded or shaped into the sled shape. Surprisingly not every type of high strength material can be molded or cut. I have stayed away from metals from the fact of all of the recalls of gas leaks. One spark could end it all.
It looks like they are injected or molded in either HDPE or UHMW. These look to be rotationally molded witch makes them hollow and lighter weight. It also makes them thinner and more prone to wear. If they were solid , they would last allot longer, but be very heavy and probably more expensive to make. If they are HDPE, they will wear out very quickly. While cheaper to manufacture, there very soft. If they are UHMW, the density is harder and will take longer to wear. (Think cutting board in a sandwich shop VS. Chain guide on a motorcycle)Thought about a replaceable UHMW wear pad? Could injection mold the main structure like you have, then compression mold/machine the replaceable block. Definitely more processes/BOM, but would make the skid last a long time with relatively cheap replacements. Guy like @MGMFRP might be able to make them from a controlled source not related to China.
Speaking of China: whatever you do, avoid Amazon marketplace. Some Chinese outfit will see sales and undercut.
Personally, I wouldn't want the metal one: you usually need a skid after a wreck, and keeping that from being a missile needs a lot more thought/beef.
I thought UHMW was compression mold only? Mr Plastic has forgotten more than I've ever learned about plastic thoughIt looks like they are injected or molded in either HDPE or UHMW. These look to be rotationally molded witch makes them hollow and lighter weight. It also makes them thinner and more prone to wear. If they were solid , they would last allot longer, but be very heavy and probably more expensive to make. If they are HDPE, they will wear out very quickly. While cheaper to manufacture, there very soft. If they are UHMW, the density is harder and will take longer to wear. (Think cutting board in a sandwich shop VS. Chain guide on a motorcycle)
I made prototypes for something similar for repo/tow truck guys years ago. There still being used today over 10 years later. I made them out of solid 1" thick UHMW. They get dragged across asphalt and onto aluminum flat bed tow trucks when they cant get a car out of the parked position. This keeps them from breaking the transmission when there towing vehicles that cant be moved.
