Throwing this out there. 2007 38ck Dune Chaser Toy Hauler.
Grease Monkey
Administrator
Staff member
We are considering getting into a Class A and if there was enough interest in our trailers we probably will.
This is my Dune Chaser. I have over loved this 5er and it shows. Everyone in camp doesn't believe how nice it is when I tell them its an 07.
Happy to discuss all the options to a serious buyer. If your looking for a Dune Chaser then you already know what your looking for and why.
2007 McKenzie Dune Chaser Fifth Wheel M-38CKS Toyhauler Manufactured by MONACO RV NON-GARAGE MODEL
DUAL SLIDES and 2 Entry doors Purchased New 2008
Below I have listed the equipment
Body Construction
102" Wide Body
Alumaframe Construction with Smooth Fiberglass Exterior
Multi-Layer Insulation and moisture barrier walls and ceiling
Front Molded Gel Coated Fiberglass Cap
Spare Tire Prep with Carrier Frame Recessed into Underbelly
Completely Sealed Underbody
NEW Tires “G” Rated Michelin XPS Rib Radial Tires w Spare Tire and carrier
New 16” Aluminum Wheels with Stainless Center Hub
6 All NEW Dexter HUB/DRUMS complete with Bearings
Beaver Tail Rear Floor at Ramp Door
2500 lb. Rated Ramp Door
WINCH 3500lb SuperWinch with Remote located in front step
Smooth Gel Coat Fiberglass Sidewalls
Appliances & Accessories
10 cu.ft. 2-Way Refrigerator/Freezer 2 Door
High Output 3-Burner Range with Oven
Microwave with Touch Control
Roll-Out Pantry with Cabinet with 3 Baskets/Shelves
One (1) Jackknife Sofa - Roadside
One (1) Booth Dinette with Table
Power Queen Bed Slide-Out with Chest of Drawers, Decorative Slide-out Fascia and Overhead Storage and Under Bed Storage
Mirrored Wardrobe doors on bedroom closed
Power Kitchen Super Slide-out has custom tire support to allow slide to open and close while vehicle tire is parked inside slide area
Dual Electric Queen Beds (lower bed is a roll over Queen sofa/bed) at rear of RV
Interior lighting controlled by Wall Light Switches
Tinted Skylight in Bathroom
Glass Shower Enclosure Surround in Bathroom
Window in Private Bathroom
DUAL Pane Safety Glass Windows
Decorator Window Treatments with Solar Reflective Mini Blinds
Sound System Surround Sound 12V Sirius Ready AM/FM Weather Band Receiver with CD/DVD Player with 4 Interior 3-Way Speakers, 2 Polypropylene Waterproof Marine Exterior Speakers, 720 watt Amplifier, 10" Subwoofer and Interior/Exterior RF Remote Capability
Wired for TV in Outdoor Storage, Bedroom and Living Room Areas Currently has a 19" TV in Living Room
Electrical Management System (50AMP/12V with 55 AMP Convertor.)
Central Vacuum Cleaner
Four (4) Exterior Recessed Docking Lights – Two Curb Side and 2- Aft over Ramp Door
LED Tail Lights
Battery Disconnect and 2- Deep Cycle Batteries in Vented Battery Box
Cable TV, Telephone and Electrical Outlet Hook-up in Basement Storage
Emergency Pump Station Shut-Off Switch
Inverter – 3000 with 4 grp 27 AGM
Generator 5.5 kw Marquis Gold Gas Onan Generator with 20 gallon Aluminum Fuel Tank, Remote Switch w Hour Meter, Fuel Gauge
Dedicated Grp 27 AGM starting battery with charge combiner to house bank.
Door-Curbside Pump Station w 40 Gallon Aluminum Fuel Tank
Utility Center Cabinet w/ Fuel Pump Timer Switch & 2 Fuel Gauges, Generator Switch, Hour Meter, Docking Light Switch
Newport Cherry Cabinet Upgrade
Laminate Solid surface Kitchen Countertop - Galley and Lavatory
Linoleum in Kitchen, Bath and Entry
Large Stainless Steel Kitchen Sink with Brushed Nickel Single Handle Pull-out Faucet
10-Gallon L.P. Gas/Electric Water Heater with Electronic Ignition (DSI)
Stainless Steel Bathroom Sink with Brushed Nickel Faucet
Brushed Nickel Shower Hose and Head
Lighted Water management System with Drain, Spray-Port Water Sprayer with 15´ Hose, Outside Shower with Hot & Cold, Soap Dispenser, Paper Towel Holder
Two 30 lb. L.P. Tanks with Automatic Changeover
One Carrier 15,000 BTU Rooftop DUCTED Air Conditioner w/ Dehumidifier and Thermostatic Remote Control
One Carrier 15,000 BTU Rooftop DUCTED A/C w Dehumidifier and Thermostatic Remote Control in Bedroom
35k BTU Ducted Furnace with Thermostatic Remote Control
Smoke Detector, LPG Gas Detector
Luggage Rack and Ladder Aluminum Rooftop
Power Vent in bathroom
Power Vent x2 Ceiling Maxi Power Vents with Thermostat Wall Controls
Large FULL Pass-through Storage area w/Doors on Street and Curb side for total Access
Large Curbside AWNING
Advantage Package
Recessed Spare Tire Carrier
Independent Front Power Landing Jacks
Rear Stabilization Jacks
Enclosed and Heated Underbelly
WEIGHTS:
Gross vehicle weight rating 18,000
Hitch Weight XXXX
Axle's weight 5,200 (3)
Unloaded vehicle weight 14,040
Tire size and load range 16" G
Measurements:
Overall Length 39'10"
Overall Height in including a/c 13’8”
Exterior Width 102"
Tank Capacities:
Water heater 10 gallons
Grey tank (100 total) 50/50 Gallons
Black Water 50 Gallons
Fresh tank (2-65) 130 Gallons + 10
L.P. tank 30 (2) Gallons
Generator Fuel Tank 20 gallons
Fuel Pump Station Aluminum 40 gallon Tank
When you see it in person you won't believe how nice it is. The outside looks better than one on the showroom floor.
Its the Gel coat Mckenzies/Monaco used. its really good and holds its shine. The trailer gets a professional polish and wax once a year. One thing that some may think is terrible. I only wash the trailer twice a year. The funny part. The day before the polish and wax and the day after the polish and wax. No soap and washes for 11.5 months.
Blacked out the lower valance last summer. Also removed both entry doors and sprayed fresh gelcoat. The coat was getting thin on the doors.
Every year I do something to this trailer to make it nicer.
I guarantee you could buy sight unseen from GM and it will be everything he says it is. Nice trailer.
1/2 ton towable? Hahaha
J/k, Good luck with the sale
Db
$25k
Won't accept offers unless in person.
My sandcar is inside. Need to unload and un Glamis the rig before it can go.
Thank you.
This Unit is way clean and GM is a stand up dude someone will get a Nice unit
Any interior photos??
Sure but nothing recent.
Its for sale but not excited about it. My next move isn't because of wealth. It's a need to move parents around in a class a or c. I'd be just fine keeping this trailer. I will miss it if it sells and good chance, regret it.
You WILL regret it ! Its a perfect setup - If i could give you some advice - KEEP IT and just get a class C to tool around in non glamis situations with the parents
  • Like
Reactions: GBR
These are great trailers! Post some inside pics for people to see! We love ours!
Will do, Trailers kinda pinned in a corner at my shop right now. Boats and work vehicles have it locked in and need some breathing room to get it out and unloaded. Been holding off as Sand Divas Can Am is in our garage at home. I need that space for the Funco at some point. Do have a deal on the Can Am. Basically its sold pending funds. So that should move soon and it will give the motivation.
