SANDPSYCHO
- Aug 4, 2021
- 246
- 348
I got a Mendeola S4 that during last season started making noise. When I'd start it, it sound fine. After I put it in gear, move it and put it into neutral and let out the clutch you could very clearly hear the tyranny spinning over the loud running V8. I also notice now I can hear it if I just start it in neutral but not as loud.. So I go to drain the oil and the drain plug is full metal.
At the start of last season the magnet was clean and got fresh oil.
This is what I was able to clean off and let sit over night on a paper towel.
The piles are not flat. I'm guessing I have a bearing going out, input shaft, main shaft? What do you think @Sean@Weddle ?
