Brian Machnach
- May 20, 2021
- 195
- 110
looking at buying the new winged air 360+ with the gateway 4G router any body have have this set up and how well you think it will work in the dunes or for boondocks camping in the desert? my TH is a 2013 keystone fusion and has the old crank up antenna.was looking at the satellite setups but the dude at camping world said don't bother as the satellite is going out and a lot of rv companys are turning to this set up but I see it needs 12 v power.im all set up for satellite prep and i can reuse my coax on roof but for me to get 12 volts up to the roof looks like a pain in the azz.but rite on the wall is a carbon monoxide detector with 12 volts and battery backup.then about 10'' away on my ceiling is my crank for the old antenna. was thinking I can take the 12 volt in wall run it a little higher then out of top wall across ceiling in a channel then up into the crank hole and to the air 360.then just run the detector on the 9 volt battery it takes.dont really watch a lot of tv more for the kids.what do you guys recommend for getting service and about using the 12 volts rite there?he then said to get a fire stick with this and it will be a sick set up.
