Stugots
- Apr 29, 2021
- 765
- 1,004
:bangin: I did not even think of that one!
I like that idea! Did you have to do anything special to just block off that egr?
Nope just made a plate and sealed it up.I like that idea! Did you have to do anything special to just block off that egr?
No issues running with the egr not being plugged in anymore or anything?Nope just made a plate and sealed it up.
None. I have done it now like this to 4 motors that are in the sand.No issues running with the egr not being plugged in anymore or anything?
I was doing that and decided just as easy to make them. Though they do look nice.You can buy plates as well.
https://www.ebay.com/itm/323743113311?hash=item4b6097e05f:g:0kgAAOSw1HxckExe
Yea I just bought the plate as well.You can buy plates as well.
I just went over to Orielly Auto Parts and they had them on the rack. I think its a 1/2" size.Yea I just bought the plate as well.
@richard h do you have a link or details on that little air filter?
Awesome i was wanting that thing gone!None. I have done it now like this to 4 motors that are in the sand.
Only if the intake is in the standard configuration. For that matter, you could just leave the valve in place.Nope just made a plate and sealed it up.
So I did flip the intake and plugged the hole under the intake and put a plate over the port on the head does that mean I can just pull the egr and not build another plate?Only if the intake is in the standard configuration. For that matter, you could just leave the valve in place.
If it's flipped, you have to block it in either upper or lower plenum.
All you needed to do was plug the intake somewhere. The additional plate would be for looks.So I did flip the intake and plugged the hole under the intake and put a plate over the port on the head does that mean I can just pull the egr and not build another plate?
Unless you are required to run an egr, its better to remove it. You never want anything other than fresh air going into your intake. EGR is better for emissions and that's about all.No issues running with the egr not being plugged in anymore or anything?
And also keep pile of sand out.All you needed to do was plug the intake somewhere. The additional plate would be for looks.
