- Thread starter
- #41
Five.five-six
- May 6, 2021
- 494
- 341
Great!
But I can barely weld and wouldn’t even begin to weld aluminum.
You are correct, there will be not HP gain by moving the injector, the issue is the issue is that the car is cold blooded and switching to E85, even though we’re using a smaller cam, the issue is going to be worse. Spraying directly past the valve should help that. If you look at the Mexican injected Beatles, they have the injectors set up that way and I’d use their manifolds except they don’t fit super flow heads.JMHO, but I doubt there will be any HP or BSFC gains by going through that exercise. leave it alone & spend the money on extra dyno time. there will be real gains there.
I sent a set of those to my builder, he’s going to do the work.
E85 and 110 octane are the same price?? I am seeing E85 in Corona around $3.15 a gallon today at the pump (not Downs). I have tested the fuel every time I fill up, I haven't seen it below 85 yet in the area.Still waiting on my long block…8 months later. Builder has 2 engines of mine to pick parts from, I’m getting frustrated.
Ive decided that since I’m doing iInner cooler, and i can buy 110at the pump now that I have a boat, and a dorum of VP E85 is about the same price as VP110, I’m just going to do a 101 0ctane engine. I can mix 110 and 91 in the drum at downs energy when I buy it.
Not sure if just running straight 101 might be best ad the leaded 110 will eat O2 sensors. 110 VP is expensive but so are O2 sensors.
We must be neighbors lol. Is that the station 76 station on Compton? I thinks he’s talking about a barrel of race e85 and not pump e85.E85 and 110 octane are the same price?? I am seeing E85 in Corona around $3.15 a gallon today at the pump (not Downs). I have tested the fuel every time I fill up, I haven't seen it below 85 yet in the area.
I just looked up the prices on my E85 app for Corona. I am just a bit South from thereWe must be neighbors lol. Is that the station 76 station on Compton? I thinks he’s talking about a barrel of race e85 and not pump e85.
