Fullthrottleguy
Site Sponsor
- 1,487
I should mention at least one person in our group carries a short handle snow shovel under his rear bench seat - - its the most useful tool - not why you think though ...I would highly recommend making sure you have the appropriate tool to remove your axles, so if you blow yore ring and pinion the trans locks up you can pull yore axles and free wheel it while getting towed.
the things I would have done last season for a triple square bit![]()
Towing out on a blown rear tire or worst I lost wheel - hub or midboard failurre is super hard on the car towing and car being towed . We learned the hard way. Our "fix" was to slip a An aluminum snow shovel under the rear arm and strap the handle the arm and it works like a ski - this also works if a wheel gets locked up . we have had to do this twice and both times it worked "ok"
