- Thread starter
- #21
URCLEVER
- 661
I will probably buy the weld in 1 for added safety
It is way more than just the hitch. Frame, rear axle weight rating, suspension, tires, brakes, trans, engine cooling .......Is it enough to just upgrade the hitch? What about the frame?
Asking for a friend
I replaced the hitch on my dually, factory hitch was rated below the gvwr for towing but isn't it more than just the receiver itself?
100% agree and I did a bunch of research before i decided to upgrade my hitch. I loaded everything in the RV for a trip, full water, fuel, propane and weighed it to see where I was at on the axle's and gross vehicle weight. I was close on the front but still had 4,000# on the rear. I made my decision after that to get a stacker. My rig is a 19 and had a 10,000# hitch the same model 2020 has a 15,000# hitch the only thing that changed between the two is in 2020 they added 1,920# to the front axle. I am under the GCWR for my rig with my setup and what I haul in the trailer. These were just thing I looked at before I made the decision.It is way more than just the hitch. Frame, rear axle weight rating, suspension, tires, brakes, trans, engine cooling .......
Coach-only, right? That's only 31k... light for a bigger pusher. I feel like I've posted this 92 times lately, but here was my old Dutch Star and stacker:you guys got me thinking so i weighed my coach. Holy chit 19500 on the rear axle and 11500 on the front. I now have to check my axle rating. My tires are good. 6900 each rear tire, frame and hitch are good now just need to check total weight loaded with stacker and Axle rating. I guess I call to Freightliner with my vin should tell me what it has. Next week I will weight loaded.
Is yours a tag axle?you guys got me thinking so i weighed my coach. Holy chit 19500 on the rear axle and 11500 on the front. I now have to check my axle rating. My tires are good. 6900 each rear tire, frame and hitch are good now just need to check total weight loaded with stacker and Axle rating. I guess I call to Freightliner with my vin should tell me what it has. Next week I will weight loaded.
No that's my issue. I'll see the weight on my rear axle next week but I'm a little concerned. Looks like one of those trailer toads might be in my futureIs yours a tag axle?
According to this I believe your rear axle weight rating is 20k and your GCWR is 42,400. What's interesting is Fleetwood keeps the same 10k hitch with/without the tag axle but the GCWR does go up.No that's my issue. I'll see the weight on my rear axle next week but I'm a little concerned. Looks like one of those trailer toads might be in my future
