2005 Regular cab Duramax *SOLD*
realtreeHD
I have to many vehicles and projects at the moment.  Took a while to find a regular cab with a clean body that hadn't been used as a landscape or construction truck.  All of the upgrades have been done in the past year.  I bought the truck early 2020 with 260,000 bone stock.
2005 Chevrolet Silverado 2500hd
LLY Duramax
2wd
Boost auto tow mirrors with heat and turn signals as well as LED reverse spot lights
Kryptonite tie rods
Kryptonite pitman idler support
3" drop shackles
Belltech shocks
Firestone helper air bags
20x12 chrome wheels
305/50r20 Nitto 420v less than 3,000 miles
S&B intake elbow
4" mbrp straight pipe
Ppe 90hp tune
Duramax store trans cooler
Duramax store radiator
Deviant trans cooler lines
Duramax store water pump
Drained all trans fluid and replaced inner and outer filters, no signs of trans damage what so ever.
Pioneer double din and a rear view camera
Replaced all speakers with Polk audio dB line.  Very good clean sound. No subs
20% Ceramic tint on side and rear windows
270,000ish miles
$13,000
This truck does not have ripped seats, has never been smoked in and has been very well taken care of.
It does have quite a few rock chips in the paint on the hood as to be expected and the cab has a dent near the third brake light.
Yes I have the handheld ppe tuner. It has the stock tune saved.
I don't have the wheels that came on the truck but I do have a set of stock size steel wheels that I can throw in.
@Kraut_n_Rice
@Kraut_n_Rice
Do you have the stuff to put the rear back to stock height?
Still have the cat?  Pass emissions in the Metro PHX area?
If I can convince my boss...this will be a parts runner that will need to move 10k worth of trailer around from time to time.
The rear going back to stock height would just be removing the drop shackles so yes it's easily reversible.
I'll check on the cat.  Not sure if I have it or not. The stupid thing is it would pass emissions with flying colors even without a cat.  Just doesn't pass the visual inspection
