Mendeola 2D to Weddle HV25 ???
Blacky2112
0
So I am looking at taking out my Mendeola 2D and installing a Weddle HV25 in a Gen 4 Funco with a EJ25 Subaru, any Funco owners do this swap before? The shift linkage looks like it will present a problem, radiator plumbing and also push my engine and cv flange location back a few inches.
Hit up onanysunday as he did an s4 from a 2d swap. Might be along same issues????
My Gen 4 had a Fortin S4 swapped in place of the 2D. Almost identical mounting and case sizes.
He E-mailed me but I don't have any specific experience and can only give generic answers. It all depends on where the 2D is currently mounted and how much room it has in front of it. Best case scenario, you can mount the HV-24 where the CV joints are in the same location so you would not need new trailing arms. This will push the engine back about 3/4", and will require some room at the nosecone. I would need pictures of what is there now to give more detail.
so is that because the tranny is just longer or that the R&P is larger than the 2D?
Have you ever seen the hv24 next to a 2d? The HV is huge. I would go with a sequential for resale value. The easiest trans swap for you is the Fortin 4 speed sequential. We swapped one into a predator with just spacers.
The HV-24 is actually almost a full inch shorter from BH to shifter shaft than a 2D from end to end.
The HV's have a longer distance from CV joint to bell housing due to the bulkhead being built into the main case for better strength, rather than the 2D having the bell housing act as the bolt on bulkhead that tightens up that distance. So when placing the gearbox so the CV are in the exact same forward/back plain in the chassis, the HV will set the engine further back than a 2D.
It all depends on where/how the 2D is mounted now. The distance from the CV joint to the front of the trans for an HV is actually shorter than a 2D, but since it is "boxier" than the tapered nosecone of the 2D, it might interfere with a rear cross member/torsion housing of the chassis.
