r3meyer
- 248
I have had the Super C (Gulfstream) setup with the 8.1 and the Allison. Seneca copy.  I hated every minute of it.  Because the ass end hangs out so far over those rear tires you get alot a sway when you start to hit the trucker ruts or they pass you.  If I was going to pass a trucker I would slam the gas, start the pass and then hang on for dear life until I got around them.  It would be fine with a lighter trailer setup, but not with what your wanting to tow.
For your budget of 30-45 you can easily find an older Monaco 97-02 pusher or a quality like brand that is already setup to tow 10k. The reliable cummins ISC and Allison combo. I went from the Super C to the pusher and it was night and day. It was a 98 Monaco Windsor with the 300HP. All of these come with a 10K tow rating from the factory.
The next issue will be your holding tanks. Those smaller class C's don't hold much water due to weight.
