wesinls
- May 6, 2021
- 880
- 1,111
If you havent noticed by other questions I've asked recently - I am new to the whole LS engine scene and more or less trying to figure things out along the way...I have no issue admitting I'm new and know nothing.
The LS376/525 crate engine does not appear to come with an alternator bracket (and alternator of course) - nor does it appear to come with the tensioner. From what I can tell there are several different variations for the alternator bracket depending upon where you want it to end up and several options for the tensioner. The manual tensioner seems like a good idea / less flop. Below is what I'm thinking...first pic of crate engine.
Questions - what do others use? How do you determine the belt size after ordering these parts, whether it be the below or a different brand / versions? When searching on Summit i put it's for a LS376/525, should I assume spacing will be correct / line up with other pulleys?
