- Thread starter
- #261
ChasingSand
- 850
The part numbers for the cams are the same, but the heads are different. I read on a J35 engine swap site that the J35A3 has the best flowing heads of any of the J motors. No idea if the heads alone would account for the difference you are seeing...or maybe the stock map on the Acura ECU (for MDX) is different than the Honda ECU map for the Odyssey?I have a J35A4 in my Tatum Sand Demon and a friend has a J35A3 out of an Acura with stock ignition box and his hits HARD from 4000 to redline, his car is a little lighter but it just rips, are the cams different in the Acura?
Couple of things to check.Well I have been trying to figure out my issue on my own without bothering all of you again but my baja is up and running I’ve got to take it around the block a few times but can’t seem to figure out the issue. 1st gear seems to go just fine 1/4 to full throttle. But when I try to open it up in other gears I get stumbling and popping sometimes shutting down until I let off give it a few and it kicks back on. If I’m not moving idle to rev is just fine no issues. I read the previous comments mentioning the screen on the vtec so after a bit of google I found the screen on my oil filter housing next to the solenoid which was surprisingly clean but I made sure it was perfect yet didn’t change anything for me. I have read some have a second screen by the power steering pump mine doesn’t. Are there any others on my set up? I’m not getting a code for anything really besides the usual suspects from having things disconnected. I have sprayed all over with some carb cleaner checking for any air leaks which there wasn’t any. Any help is always appreciated thank you again.
Fuel filters clean??Well I have been trying to figure out my issue on my own without bothering all of you again but my baja is up and running I’ve got to take it around the block a few times but can’t seem to figure out the issue. 1st gear seems to go just fine 1/4 to full throttle. But when I try to open it up in other gears I get stumbling and popping sometimes shutting down until I let off give it a few and it kicks back on. If I’m not moving idle to rev is just fine no issues. I read the previous comments mentioning the screen on the vtec so after a bit of google I found the screen on my oil filter housing next to the solenoid which was surprisingly clean but I made sure it was perfect yet didn’t change anything for me. I have read some have a second screen by the power steering pump mine doesn’t. Are there any others on my set up? I’m not getting a code for anything really besides the usual suspects from having things disconnected. I have sprayed all over with some carb cleaner checking for any air leaks which there wasn’t any. Any help is always appreciated thank you again.
How did you plug the EGR?picked up my kit from Kennedy today. Got the motor cleaned up and painted figured how to flip the intake and the plenums.
Probably going to make a plate or look into the guy out of ArizonaHow did you plug the EGR?
my neighbor has an older SCU with a VTEC. He is looking for someone to help him with the engine wiring harness- it’s been modified, and he’s got 3 wires he hasn’t been able to identify.
Who is the shop or person he should contact?
the wire layout from ecu that I have ismy neighbor has an older SCU with a VTEC. He is looking for someone to help him with the engine wiring harness- it’s been modified, and he’s got 3 wires he hasn’t been able to identify.
