Jersey_Jeff73
- May 6, 2021
- 558
- 404
we ran a peterbuilt with a c12 cat across with a 53 trailer and 5 canams 9.5 mpg
RVHaulers with Gregg, he's up in Canada.What's the name of the channel?
This happens to me. I prefer to ride in the second lane over because of less potholes. Problem is i cant keep the 80mph trucker pace. Even the slow lane i feel in the way at times. Has CHP decided to ignore the 55 truck speed limit? Fine with me if they deem it safe based on a visual drive by of the truck. Brakes and technology keep improving. Dont most trucks have trackers? I heard some have devices that will apply the brakes. I think about that when a trucker dude blows my doors off and im doing 60mph. They must be independent and dont have a tracker and mean boss to answer to.Part of me thinks I’ll find it unsafe as trucks are ignoring speed limits all the time in CA and flying by you at 65-70.
That's the classic "gear fast, run slow" mantra, interesting to see mileage gains that high though. Suppose it makes sense given that the load is so much lower than grossing 80k. Was seriously considering the Class 8 route when we were in the market for a larger 5er as buying a used Class 8 truck was cheaper than a newer diesel pickup to pull the same load, not to mention the benefits of engine braking / air brakes. Only downside was lack of off-road capability vs a 4x4 pickup, we tend to end up in some interesting places and burying a rig that heavy isn't high on my list of things to do.There's a guy who buys used class 8 trucks, converts them to RVs for towing and changes the gear ratio to a taller one. He does YT videos showing off his fuel economy towing a 24,000 lb trailer. One truck got about 9 mpg towing and when he changed to a taller gear, it went up to 10.5 mpg. Empty, that truck got about 16.5 mpg before and about 17.5 mpg after. He got very similar results with another brand of truck. One had a 12 speed auto shift and the other had I believe a 13 speed automatic.
In addition to the obvious safety benefits, those big rigs are getting better mileage than my truck towing an estimated 19-20k. Not to mention they can carry 300 gal so you can fill up whenever you find a great deal on diesel. Regardless of where you live, you don't ever need to buy fuel in CA again.
I've seen a couple of videos where guys have done testing and their results were to keep it right at the torque peak and that's where the engine is most efficient. Whatever the mfr says is the peak tq rpm, set the cruise at that. It might be 60 or 62 or 59, but that's where the engine is most efficient.I normally stay around 65-68 but I’m determined this summer on our 3,000 mile trip to stick around 56-57 to see if I can’t maximize the fuel economy of the Ford 7.3L. Part of me thinks I’ll find it unsafe as trucks are ignoring speed limits all the time in CA and flying by you at 65-70.
CHP pulled me over at the BP Check point one year and told me slow down, the sand dunes aren't going anywhere... :lol:I'm guessing the sand will still be there even at the late hour.
You are going to need that extra fuel to run the generator for the a/c this weekend. Looks like temps will be in the upper 90s.Just pulled on to gecko road and the gauge is right at 3/4 or just maybe a pinch below certainly higher than it normally is halfway through the trip. Looks like it took about an extra 20 minutes. Looks like maybe a nice payday here.
Yup. I feel like a nuisance “crawling” the speed limit when people are blowing past me. With all the construction on the 10 east in Beaumont/Banning and the small #4 lane, it puckers my hole as I’m driving up against the k rail.This happens to me. I prefer to ride in the second lane over because of less potholes. Problem is i cant keep the 80mph trucker pace. Even the slow lane i feel in the way at times. Has CHP decided to ignore the 55 truck speed limit? Fine with me if they deem it safe based on a visual drive by of the truck. Brakes and technology keep improving. Dont most trucks have trackers? I heard some have devices that will apply the brakes. I think about that when a trucker dude blows my doors off and im doing 60mph. They must be independent and dont have a tracker and mean boss to answer to.
I’ll have to look in to this and see the peak range on the Ford.I've seen a couple of videos where guys have done testing and their results were to keep it right at the torque peak and that's where the engine is most efficient. Whatever the mfr says is the peak tq rpm, set the cruise at that. It might be 60 or 62 or 59, but that's where the engine is most efficient.
I'm with you on that East bound stretch 10 freeway by Banning and Cabazon. It has small lanes with trucks fling by with k rail so close on the right side. There is no where to go if someone drifts out of there lane. Sometimes I think our mirrors are going to touch as they fly by. One time I checked the mirrors and saw a semi drifting in and out using his lane and my lane. So I hot footed it and found a break in the k rail for a short distance and then slowed to let him go by. As he went by I looked over and could see he had a pair of drum sticks in his hands as was drumming on the dash and steering with his knees. :drummer:Yup. I feel like a nuisance “crawling” the speed limit when people are blowing past me. With all the construction on the 10 east in Beaumont/Banning and the small #4 lane, it puckers my hole as I’m driving up against the k rail.
