- Thread starter
- #61
onanysunday
- May 7, 2021
- 3,575
- 3,382
Whatever Mike at Turbos Direct sold me. I will have to look at the numbers.is that a 3.0? that looks like a big turbo for that.........
You want better power you could start by having a gen 2 GTX series turbo or the g550/660 turbo and it would give you so much more instant response it will feel like a new car. They aren’t cheap but worth every penny. Ditch the t4 exhaust housing. You woul be amazedWhatever Mike at Turbos Direct sold me. I will have to look at the numbers.
3.5L. They make lots of exhaust energy though, so spool generally isn’t bad.is that a 3.0? that looks like a big turbo for that.........
We will see what it does with this turbo. Already hemorrhaging money on this thing. Built a heat shield today to protect that alternator wire. It won't burn up again. I think I'm going to add a second plate about an eighth to a quarter inch away with an air gap between it. Now I can fix the wire.This thing also developed what felt like a lean pop this last trip. Just put in fresh plugs. I also installed a virtually new a1000 fuel pump. The original was 17 years old. Still working but figured I might as well put the new one in. It had only been run to dyno a car and then pulled off. I think I'm going to add a second plate to both my other heat shields with an air gap between and get rid of the heat barrier that has deteriorated over time. Called the station at 91st and Olive today and they confirm what I figured. The flex fuel with 50/50 mix comes with 87 octane as the gasoline portion. Last trip I had mixed it with 91. So I have about 20 gallons I have to give away. My normal Chevron has not had it for a couple weeks. They told me it is not a supply issue but a driver issue getting it delivered. Seems strange.You want better power you could start by having a gen 2 GTX series turbo or the g550/660 turbo and it would give you so much more instant response it will feel like a new car. They aren’t cheap but worth every penny. Ditch the t4 exhaust housing. You woul be amazed
Can you try and mount the drain lower on the block to help create a vacuum?My turbo drain line has always been an issue. Too steep of an angle and does not drain properly. Wants to push oil past the seal and smoke. I had built a reservoir up top at one point but still obviously not enough volume. Going to give this one more crack and try to make it mechanically drain. Otherwise it will be a $440 turbo werks 10,000 hour scavenge pump.
Well there is already a hole in the side of the girdle where it is. I guess I could go a little lower and still stay above the oil level.It could be getting windage up where it is at as well. I think for now I will try the same spot with a larger tube coming from the turbo. Then set it up so I can drill the end out and drill the same hole to go to a dash 12 from the current dash 10.Can you try and mount the drain lower on the block to help create a vacuum?
I cut off the steel fitting from the old drain and then machined it. Then machined a ring so it all pressed together. Easy to weld it and get it exactly perfect. Put in a new piece of braided hose and kept it at one inch long. Just enough to flex a little bit. I'm curious about everything and couldn't help myself. Had to measure the volume from the old drain to the new drain. Old one was 75 mL and the new one is 180 ml. So double the volume. Hopefully this will do the trick.Thats a big difference in gravity feed. Shouldn't have any issues now. Are you going to weld an AN Bung to the downpipe and use a hose to connect them?
have sat and thought about the best, cleanest way to do things a lot on my own car, like lots of hours and the more you think, the cleaner it gets, but whos going to pay for that right?
It is, just putting mine back together now. The nice part is getting to finally make all the finishing touches just like you want. The hardest part of the job is the thinking about it before you start.
It has one on it now. Just not working. Either a setting or the controller not working. Car goes on the dyno next Saturday.That boost controller will make boost response a different animal unless you already have something similar. Can tune the response to like it is now with a ramp, or fill in some of the transition for much quicker response.
Word. You know what to expect then. Curious how well it works, I have a mechanical one right now, but would be nice to be able to adjust on the fly for more temporary boost at the drags.It has one on it now. Just not working. Either a setting or the controller not working. Car goes on the dyno next Saturday.
If I am running low boost (7-8 LBS) is a boost controller necessary? I am reading conflicting Info on the innerwebs.It has one on it now. Just not working. Either a setting or the controller not working. Car goes on the dyno next Saturday.
You are on spring only which is fine. A controller needs an output from the ecu to run it. Pulse width modulation output. All it does is put pressure on the back side of the wastegate to keep it shut then open for more boost. At least that is the way I understand it. Very simple design. Also stops the creep you get from just the spring.If I am running low boost (7-8 LBS) is a boost controller necessary? I am reading conflicting Info on the innerwebs.
Not sure if one would help or really do nothing in case.
Helps the boost ramp become sharper. With the wastegate only, you're pressurizing the dome on the wastegate all the time. So when it's at 2psi, you're putting 2psi of pressure on the spring and partially opening the wastegate. This dulls boost response a little since a spring is linear and is fully open at whatever the spring pressure is. The reality is slightly different, but basically your 7lb spring is opening the wastegate halfway at 3.5psi.If I am running low boost (7-8 LBS) is a boost controller necessary? I am reading conflicting Info on the innerwebs.
