Rockwood
- 8,375
Couple of months. Was using solar to charge it in his class C.any idea how old it was?
what was he using to charge it?
what was it in?
Lots of new Chit for me to learn with this battery tech...
what was it in?
Also an equal charge test it takes 4 hours to charge LiFePo4 vs 10 hours for a SLA. More then double the Gen run time.View attachment 30471
Technically, you can discharge down to 0% and they’re fine, but recommended to stay above 20% for best life. Lead acid don’t last long when discharged beyond 50%, which is how people say a 100ah LiFePo4 is equivalent to 200ah.
Does your charge controller have any type of "storage mode" for lithium batteries? It would keep them roughly 50% charged. Its a very common feature on chargers used for RC planes that use lithium batteries. Im not sure if that technology is common to the RV world yet.Do I leave the trailer plugged in all of the time and let the charger monitor the battery and take care of it,
Unplug your converter. Its only job is to recharge at high amps when you're actively using the trailer. You want to just use a simple trickle charger designed for these batteries. I use these on all my toys that have LiFeP04. I have 6 of them in total.So after talking with @Lord of the Dunes and reading this thread (btw, thank you folks, for your jnput) and a few other online sources about LiFePo4 batteries I pulled the trigger on one, 100 AH battery from Ampere Time.
@Lord of the Dunes, Also suggested i install this shunt, which has a Bluetooth app that will monitor the battery state.
It's only been in for a few days and for better or worse, it will not really get tested until next fall. I can't imagine it won't work fine for me, the question. Is longevity.....
The charger controller I have uses these little donglsles to control how it charges the batteries based on the type and configurationof the battery. Now that i have the LiFePo4 battery i had to buy the correct dongle. Kind of clever, if you ask me.
My only question right now is, how do I treat this battery? Do I leave the trailer plugged in all of the time and let the charger monitor the battery and take care of it, OR leave it unplugged all of the time and allow it to discharge a bit between charges? I'm a lazy ass and would love to just leave it plugged in and let the charger do its job.
https://www.amazon.com/dp/B07W6B987F?ref=emc_p_m_5_i
The IQ4 LIFEPO is tailored for use with today’s state-of-the-art LiFePO4 batteries that use a Battery Management System. The IQ-LIFEPO allows the DLS to deliver proper voltage to charge the larger 4-cell design of the battery and remains in a stand-by trickle mode ready to deliver a fresh BULK charge when needed.
Installation
The IQ4 LIFEPO Smart Charge Controller easily plugs into the Dual Voltage Jack of your IOTA DLS Battery Charger. Once plugged in, the IQ Smart Charge circuitry is automatically engaged and your IQ module will activate. Your DLS will now provide an automatic and trouble free charging profile to your batteries!
Yep youre right and at least you noticed. Its a very small different. Flooded lead acid batteries like a slightly higher voltage than AGM. So if you use that dongle during the summer time the AGMs were probably not the happiest of campers.This charger allows for Dongles that control the charger for whatever battery type and configuration you have. I used to have the lead acid dongle (which was probably not right for 2 AGM's in parallel, but thats the way it was)
Trying to think of the most simple way to explain this. Break it down into 2 scenarios.It "seems like" I should be able to "set it & forget it". Im asking because Im not familiar with this battery technology...
