Fox 2.0 16" 3 tube bypass
Chingon619
Anyone looking to add bypasses? These are in excellent shape and ready to install but I screwed up and bought the wrong size. I need 18" unfortunately. In San Diego. Shipping on your dime.
$1,500
if you remove the alum sleeves at the bottom looks like you'll have your lost 2" Is the eye to eye correct? Looks like someone just destroked them.
Welp, I haven't mocked them up yet and found some 18s I'm trying to buy, but owning 4 rear bp shocks isn't in my cards lol I will be running microstub so maybe my travel will be limited anyways as compared to my G1 midboards. If they don't sell, I will mock them up. I did notice the spacers and thought about that. I really don't know enough and that pains me 😆 I was told to put them on and cycle the suspension and see what it does. The upper mounts on my frame aren't that staggered as much as others I've seen, so who knows. I appreciate the heads up, I know you know what's up. Thank ya!
Bump!
Just saying, that if the extended length eye to eye is correct for 18” shocks, an you have 16” from the bottom of the shock body to the top of the alum. bushings, then they are simply just “de-stroked” 18” shocks..
That, or if they’re 16s, extended eyelets might get him to 18” shock overall length
$1,500
Do you happen to know the length eye to eye compressed and open? I may be able to use them.
According to this... but I got like 41.25" extended. So it could be a different end? So I'd imagine the compressed would be 25" approx. I'm not willing to discharge them to find out, sorry. Let me know, feel free to text me at 619-495-4064 thanks!
Edited to add: please not there is a spacer installed about 1.5" I'll need to measure again, that can be removed on the shaft you can see in the pic.
2 Compression Adjusters
1 Rebound Adjuster
2.0" Diameter
16.0" Travel
40.100" Extended
24.100" Collapsed
2" x 11" Reservoir
0.875" Shaft Diameter
1.25" Mounting Width Between Tabs
Uses 1/2" Shock Bolts
90 Compression / 50 Rebound Standard Valving
The Valving in the description and the engraving also match.
Just let the nitrogen out of them so you can compress and measure them, push on the schrader valve until no more gas comes out. The installer will have to discharge them to install them anyways. It's no big deal.
If you don't already have a nitrogen tank and regulator to fill shocks, I'd highly recommend getting one. I've got less than $150 in my nitrogen setup and I use it for many things, not just filling and topping off my car's 8 shocks.
Sold in the washes NYE how cool is that!
Wish I would've updated the price in here, took a hit on em' gone for 1200. Ah well, win some lose some. Next!
Too bad I can't just delete this thread or even just edit the original post to sold and leave it buried.
They were really nice bypass shocks! I paid 1500 a while ago and they never come up.
Hey, what great weather we had for the weekend huh? Couldn't be happier except for the dunes were rutted out bad.
Ok, I'm done. LOL
Happy New Year!
