Richard h
- 1,323
Looking at a s5d and not sure 1 where you check fluid level and 2 where you fill at on box.
That's it. I have a large funnel with a hose clamped to the end. I zip tie the funnel up high on the chassis and run the hose into the fill hole.
Thank you. I did pull this out nothing leaked out. I will pull it and level trans and see where I'm at.That's it. I have a large funnel with a hose clamped to the end. I zip tie the funnel up high on the chassis and run the hose into the fill hole.
You're welcome. You can use a small allen wrench to stick in there and see if the liquid level is close to the fill hole.Thank you. I did pull this out nothing leaked out. I will pull it and level trans and see where I'm at.
Thanks again.
Good idea as my finger will not reach with the depth of the threads.You're welcome. You can use a small allen wrench to stick in there and see if the liquid level is close to the fill hole.
