ChasingSand
- 889
pegasus has quality items,https://www.pegasusautoracing.com/productdetails.asp?RecID=10285
Work well. Spade connector is less likely to F up.
How is your system wired? Are you using this switch to ground the fan motor or are you using the switch to ground a fan relay? I would thing that without a relay your problem might be an overload on that little thermal switch. Just my .02Pulled out my water outlet today for another repair and the fan switch pretty much broke when I tried to unscrew the connector. Only lasted one season. Anyone have recommendations on a solid brand?
It’s wired to ground the relays.How is your system wired? Are you using this switch to ground the fan motor or are you using the switch to ground a fan relay? I would thing that without a relay your problem might be an overload on that little thermal switch. Just my .02
did you crank down on it?Pulled out my water outlet today for another repair and the fan switch pretty much broke when I tried to unscrew the connector. Only lasted one season. Anyone have recommendations on a solid brand?
I didn’t at all and is very strange that it broke like that. Going to replace it with a different brand and see how that works.did you crank down on it?
you can also solder ends back on it,
