Rockwood
- 7,870
Baby Physics Jesus frowns upon some posts in this thread.  :biggrin:
The reason your hitch has different ratings for with/without WD hitch is because the bars (or cables or whatever your setup has) take vertical load (green arrow) when the system is out of alignment and convert it to horizontal load via spring tension.
This is why it's critical to set them up so everything is in line.
Just because your truck doesn't squat or you don't see much decrease in front ride height when you hook it up doesn't mean you're not cantilevering a metric arseload of weight (which is multiplied on every bump) on your frame. Just because it looks good when parked doesn't mean it isn't doing anything on every bump in the same way we don't tune the crossover on your buggy's suspension based on how level it looks when parked. The engineer that did the calcs for your hitch spent a lot of time on that, don't disappoint him. :biggrin:
In short: run them. Yes, they take time to set up, but there's a reason the numbers are different, and it's not because it makes you feel better as a driver.
