Wheel stud stripped out of hub, Can it be repaired?
LtPyro
May 6, 2021
182
71
When I was at the dyno shop last week, they stripped a wheel stud out of the hub when removing the wheels.  All the knurling is gone.  Is there any way to repair it and get the stud back in?  Or am I going to have to purchase new hubs?
Thanks
I believe you can measure the stud hole and go to Napa and they can try and get you a new stud with same lug nut size just bigger splines.  Thats what I did for my Subi, but then again Im not pushing the HP you probably are.
What @JBL said.  Take the hub down to NAPA or wherever, find the next size up on the knurling and press it home.
You could have a fabricator Tig weld up the hole a bit and redrill it to the correct size if you can't find a stud to work.
You can get a stud with a bigger knurl but retain the stud size (consult a Dormann catalog), the stud is likely 14 x 1.50. If you go that route I'd ream the hole to the new knurl size (there will be an exact specification for hole size depending on what material it is being pressed into, smaller for aluminum and bigger for steel) drilling it can be tricky and it may end up off center or crooked, you want the stud to be perpendicular to the flange face and not at an angle. It's best to remove the wheel flange and perform repairs with a mill or drill press, and then use a press to reinstall the new stud. You may get lucky and find a replacement stud with larger knurl and not have to enlarge the existing hole. An adjustable reamer is the best way to enlarge the hole IMO if you need to though, and press in the new stud DO NOT use a lug nut to pull it in. If you don't have access to a press you must use a thrust bearing and washer under a nut lubed with anti-seize to pull in the stud. The flange is aluminum and very easy to fawk it up.
