HEADINJURY
- May 6, 2021
- 671
- 728
Diablo won't be for a while. I think they are trying to get out the El Jeffe as that has the most orders.On a Diablo? Probably not happening.
In 5 years the Speed will be thoroughly outdated. Might be the beefiest option on the table, but if the 2L wave continues, 300hp will be a pump gas thing, not E85.What kind of answer is that? You are stating the obvious.
Again, how is it detrimental to me to not have a Speed UTV right now?
What kind of harm am I experiencing? You seem to have all the answers. Let's hear it.
Bronco deposit I believe was $100.People put way more than speed asked for street cars....and wait... Bronco's anyone?
Ford announced the Bronco in June 2020, and accepted orders January 2021. First delivery was July 2021.People put way more than speed asked for street cars....and wait... Bronco's anyone?
Not only that it is from a company that has a long track record providing products.Ford announced the Bronco in June 2020, and accepted orders January 2021. First delivery was July 2021.
Yes, there are still thousands waiting, but they've been pushed back months, not years, from their promise date. :biggrin:
:bag:Nobody did. Car does not have EPA/CARB certificate yet.
@Rockwood that’s a picture that I took from the pre production car that had the old style “tabs”. The new redesigned one is a forged “U shaped radiused center bracket” that is wrapped around the tube with a hole in the center. That hole gets a rosette weld. Look closely at this picture.I don't think the problem is how the mount is affixed to the chassis, but more the mount itself. It's a couple 2D 1/4" tabs sticking out, and it failed because the tabs are just chillin out there with no support. Look at where it broke:
Even the whack-ass booger welds in the middle held, it's the tab itself that failed. Adding more weld to the middle of the mount isn't gonna help. Every time you hit a bump, camber changes, drifting, etc, you're putting lateral stress on a 2D part. Like you said: tying the tab horizontally to the tube, or tying them together, is the solution here.
Forged tab will be nice and super strong forged steel everywhere but the welds, where the grain structure will look more like a cast piece. On the outer pivot, putting it into the end of a tube works great (like the inner C of a steering live axle) since you're putting the weaker welded part on the thick-ass slug. With the inner pivot tabs, you've put the weld at the base of the tab, which isn't the most awesome place to put your weak point.
We shall see, but as stout as this chassis is, I think the suspension mounts themselves are the likeliest place for failure, both front and rear. Rear is an easy fix even if it fails... Assuming it didn't fail at 70mph on Zoo Road. :biggrin:
@NIKAL Didn't you say it was done?Nobody did. Car does not have EPA/CARB certificate yet.
