Rockwood
- 7,286
4WD helps share the load, the front driveshaft spins all the time anyway.
I would suggest 32's for the ride height. Plenty of power to push them. We even run 32's on the non-turbo.For the turbo xp non s version do you run the 30” ss360s or 32”. Stock tires are 30”.
Does it rub at all? I recall a couple situations where I rubbed with a tall set of buffed front Skats that measured around 31"I would suggest 32's for the ride height. Plenty of power to push them. We even run 32's on the non-turbo.
I would run what ever size came with your X3, i got the 30" ss360 and they are a couple inches taller than the stock 30" bighorns.What size SS360’s and paddles are you running on the late 200 horse model X3?
Are you running 30's on a 14" or 15" wheel?I would run what ever size came with your X3, i got the 30" ss360 and they are a couple inches taller than the stock 30" bighorns.
Looking good. 32's make all the difference. Happy duning!!32 inch ss360hp's in the rear and the normal ss360's in the front...method's "griplock" wheels - lighter than beadlocks and provide similar functionality - plus weigh less than most traditional beadlocks. Couldnt be happier.
Get the 32" SS360s. You can run them no problem and the extra ground clearance is good. My friend runs the 32" on his 172 hp X3 with no issues.What size SS360’s and paddles are you running on the late 200 horse model X3?
Those griplock wheels are no joke. They were the hardest wheel to get the tires off. Took it to a tire shop and they struggled due to my paddle tire set up not having a stiff sidewall like a regular tire. If you debead a tire on those wheels you did something special.32 inch ss360hp's in the rear and the normal ss360's in the front...method's "griplock" wheels - lighter than beadlocks and provide similar functionality - plus weigh less than most traditional beadlocks. Couldnt be happier.
32" in the sizes you mentioned is what most are running. I think they have a 33" tire now.What sizes are you guys running the 32 SS360? 32x10x15 front and 32x12x15 on back? or ??
