Mac
- May 3, 2021
- 947
- 2,193
Sorry. I run 10.5x15sDo you have a part number for the electric motor by chance?
Does anyone have experience running these with 12.5-17 fronts?
it's from this guy - i dont think there's a part number on the unit itself - if you call him he might tell you??Do you have a part number for the electric motor by chance?
It has the normal Extreme labeled rack (not sure who actually makes this rack for them) and a 400W Electric Motor, not sure of the brand, I would have to pop the hood off to check. I'm running 33's on the front but I know he uses the same setup on 35's as well.What system does it run as far as a rack and the unit model itself?
I will be going to a manual rack if I go this route. Although I did not think of that. Cool.If you're keeping a hydraulic rack, you can just loop the lines to keep everything lubricated, but disable the power assist.
You now have me thinking. I could easily put my Gen 4 rack back together. Teeth have some wear on the center teeth where it rides going straight but not horrible. Normal wear from the amount of miles on the car. For sure the aluminum for my spool valve is considerably worn and Grant has an upgrade for that if you keep the stock rack. The two aluminum machined blocks at each end are now unobtanium. I believe he said 2008 was the last year for that rack or those parts. Mine have some wear but I think the could be sanded and used again. It is not a load bearing surface. I did have one boot full of oil where it went past the two o-rings. Anyway I digress. If I put my stock rack back together and just packed grease in for the gears I could then in my case put the EPAS unit inline of the steering shaft. That would be a ton less work than putting in my gear one super rack which will be out of the truck this summer at some point. That project will be probably 100-150 hours of labor alone.If you're keeping a hydraulic rack, you can just loop the lines to keep everything lubricated, but disable the power assist.
I think the Funco rack is a modified OE rack from somewhere.You now have me thinking. I could easily put my Gen 4 rack back together. Teeth have some wear on the center teeth where it rides going straight but not horrible. Normal wear from the amount of miles on the car. For sure the aluminum for my spool valve is considerably worn and Grant has an upgrade for that if you keep the stock rack. The two aluminum machined blocks at each end are now unobtanium. I believe he said 2008 was the last year for that rack or those parts. Mine have some wear but I think the could be sanded and used again. It is not a load bearing surface. I did have one boot full of oil where it went past the two o-rings. Anyway I digress. If I put my stock rack back together and just packed grease in for the gears I could then in my case put the EPAS unit inline of the steering shaft. That would be a ton less work than putting in my gear one super rack which will be out of the truck this summer at some point. That project will be probably 100-150 hours of labor alone.
I have a couple of friends that constantly need jump packs, no issues with their EPS units failing.I have the Kartek eps unit, too lazy to build my own and i couldn't get ahold of other people that sold them. The one my car came with never worked correctly, so I bit the bullet and changed it.
I had read somewhere that jump starting a car can mess them up, so I put it on a breaker to shut it off just in case. Don't know if its true, but better safe than sorry.
