Dunatic619
- Mar 30, 2025
- 14
- 0
Thanks guys!! And I got a new main seal going in as well. Thanks again for the responses.
The amount of sand between the engine and adapter plate when I tore it down.View attachment 154254
Do you think that much would come in just from the two open holes?The sand is coming in from the top. The bent sheet metal piece bolted to your adapter is typically enough for the bottom. Clean up the mess, install a new seal, and plug the highlighted holes with a finger full of silicone.
If it's been a couple seasons since the trans was out, or seal replaced, yes. If it could get in through the bottom, it would likely leave that way too.Do you think that much would come in just from the two open holes?
Thanks for the info and insight!If it's been a couple seasons since the trans was out, or seal replaced, yes. If it could get in through the bottom, it would likely leave that way too.
Wasn't there somebody that complained that their engine valley filled up with sand or water after they had sealed those holes? Maybe I'm recalling that wrong..The sand is coming in from the top. The bent sheet metal piece bolted to your adapter is typically enough for the bottom. Clean up the mess, install a new seal, and plug the highlighted holes with a finger full of silicone.
Probably. People bitch about free ice cream.Wasn't there somebody that complained that their engine valley filled up with sand or water after they had sealed those holes? Maybe I'm recalling that wrong..
Something to think about.
I know Chris at benchmark performance would use weather stripping around that seal that squished between the trans and the motor
Bad wording on my part. What I was trying to say was that I made usual deletions and modifications to the stock harness to work with a buggy."to as usual"
Please explain.
